Author Topic: 2012 JKU Front Drive Shaft  (Read 108 times)
Offline DAMTALL
  • Thread Jackin' 24/7
  • Jackin' Threads Since 2012
« on: July 08, 2021, 09:26:34 PM »
So I have been looking at front drive shafts for my 2012 JKU.  What are the two numbers associated with the shafts, 1310 and 1350?  Thanks!
Big Mike - 2012 JKU Crush, 2.5" Teraflex Lift with Shocks, JKS Quick Discos, RockHard4x4 Skids and Evap Relocation Bracket, JCR Crusader Bumpers (mid-width front, mid-width rear), Teraflex HD hinge tire carrier, SmittyBilt h2o winch, 16x8 ATX wheels with 315-75-16 General Grabber AT2's.
  • Please don't break, please don't break, please ...
« Reply #1 on: July 08, 2021, 09:27:55 PM »
That sounds like the u joint options for the ends of the shaft. 2 different sizes.  You need to pick the one that works with the yokes you have on the transfer case and axles.
4.5" lift and 35s
Trail toy now
Offline zuke
  • Member 2021 VA4WD
Re: 2012 JKU Front Drive Shaft
« Reply #2 on: July 09, 2021, 07:03:28 AM »
Stock the front is a 1310 that goes into an adapter and flange plate setup, rear of the driveshaft is an Rzeppa joint....
If you're looking to upgrade, you'll want to replace the front yoke on your transfer case to accommodate a regular double cardan CV Joint, generally when you order a driveshaft from Adam's or Tom Wood's, That comes up as an option.
John
2020 JT Sport S
2015 JK Rubicon
2015 JK Unlimited Sahara
2006 TJ Rubicon
1999 TJ HC Wheeler
1998 TJ SE
« Reply #3 on: July 09, 2021, 08:31:31 AM »
« Reply #4 on: July 09, 2021, 08:35:29 AM »
CJs are so much simpler.  Although I considered the CV style when I replaced mine.  But opted to not.  Maybe if this becomes some crazy rock bouncer.  But not for now.
4.5" lift and 35s
Trail toy now
Offline zuke
  • Member 2021 VA4WD
« Reply #5 on: July 09, 2021, 09:21:17 AM »
As long as you keep the front on leaf springs, it's probably not worth the hassles to switch to a CV... I went down that road with my Waggy, and getting the pinion angle right with a CV Shaft and more than 4" of lift pretty much means doing a "cut and turn" on the axle if you want to keep caster and steering angles correct...
John
2020 JT Sport S
2015 JK Rubicon
2006 TJ Rubicon
1999 TJ HC Wheeler
1998 TJ SE
« Reply #6 on: July 09, 2021, 09:23:39 AM »
Good info.  I was worried about the rear after installing the auto.  The rear DS length shortened.  But since it is a Scrambler, I think I still had enough length.  If it were a 7 or a 5, I might have had to go CV
4.5" lift and 35s
Trail toy now
Offline zuke
  • Member 2021 VA4WD
« Reply #7 on: July 09, 2021, 09:37:57 AM »
Oh, the rear is easy, If you decide to go to a CV in the back, you just use wedge shims until you get the right pinion angle... the only real concern in the back is keeping enough oil in it, because as you lift the pinion, you lower the fill hole and the amount of oil you can fit before it starts to spill out. That's pretty easily remedied with a diff cover that has a higher fill hole.
But, if you have enough length in the shaft right now that you don't get any bind at full droop, there really isn't much to be gained with a CV shaft. (It does lift your pinion up out of the rocks, but as you said, the Scrambler isn't at crazy rock bouncer status... yet :) )
John
2020 JT Sport S
2015 JK Rubicon
2006 TJ Rubicon
1999 TJ HC Wheeler
1998 TJ SE
