Author Topic: Welders  (Read 403 times)
  • Member 2019
Welders
« on: December 15, 2019, 10:04:56 AM »
I've been borrowing a buddies Hobart 140 MIG lately, because my cheap HF flux welder isn't up to the task for recent projects. Given my novice welding skills, I'm looking to buy a good quality MIG.  My requirements are I'd like to have a dual voltage model, i.e. 110/220 capable.  I also don't see myself ever having a need for more than 1/4 steel, but looking at the Eastwood MIG 250, it meets and exceeds my requirements.  I know Miller and Lincoln are the go-to choices for welders, but what interests me about the Eastwood model is the price, reviews, portability and 3 year warranty.  Any thoughts would be appreciated!
  • Member 2019
Re: Welders
« Reply #1 on: December 16, 2019, 07:29:45 AM »
Go to TSC and pick up a Hobart. They are the best bang for the $$ I have a Handler 190 and love it. The dual voltage is available, in other models. I need a bigger bottle the lil pony bottle is not large enough. It's a great back up because you know you always run out of gas at the worst time. But I would recommend at least a 80CF.
  • Member 2019
Re: Welders
« Reply #2 on: December 16, 2019, 09:24:48 AM »
I looked at the Hobart Handler 210MVP MIG.  However, it was more expensive than the Eastwood model, had a complicated 5/3/1 warranty and only handled up to 3/8".
Offline RattleTrap55
  • Member 2019
  • 84 CJ7
Re: Welders
« Reply #3 on: December 16, 2019, 09:44:56 AM »
I have a 140 Amp welder that is great for most of my jobs but like you I am interested in something a with a little more power & versatility. After quite a bit of searching and reading reviews I have settled on the ESAB Rebel 215ic combination MIG-Stick-TIG welder (Note they offer the 215 in a variety of packages)
https://www.weldingsuppliesfromioc.com/esab-rebel-emp-215ic-mig-stick-tig-welder-0558102240
This kit offers the things I want most, ability to weld up to 3/8 steel, dual voltage, TIG capability, and a long list of available options using standard connections all with a reasonable duty based on my "hobbyist" needs. It is a little pricey at $1,500 ($1,699- $200 rebate) but still cheaper than buying a separate MIG / TIG welders.
The 215ic MIG only configuration comes in at just under a $1,000 ($1,195 -$200 rebate). If you decide you want any or all of the options you can always purchase them as need down the road.
Just one guy's opinion.
Garner
4" Lift on 33's
4.2L w/HESCO MFI & Howard Cam
T-5 & Dana 300
Smittybilt 9,500 Winch
Spartan Locker
2018 JKU - box stock
2002 TJ Sahara w/Very Rusted Frame
  • Member 2019 VA4WD
Re: Welders
« Reply #4 on: December 16, 2019, 02:38:02 PM »
Been using a Millermatic 211 for a few years now.  easy to use and will make a novice  weld like a seasoned professional  ( or at least that is the  tag line in the brochure).   It is dual voltage and I have used it to weld up everything from tin to tractor frames.  Just set the wire size and dial the thickness in and make two pieces one.
"Talent hits a target no one else can hit; Genius hits a target no one else can see"
  • Member 2019
Re: Welders
« Reply #5 on: December 16, 2019, 03:10:59 PM »
Garner
Well if you want to buy one to last a life time and you got the chips. This is the bees knees.. Inverter welders that can do all 3 are a big hell yeah!  Spending that kind of cash I'd go Miller then ESAB.
Offline dave2002ti
  • Member 2019
Re: Welders
« Reply #6 on: December 19, 2019, 01:37:01 PM »
[/quote]
But Ian uses a ESAB
  • Member 2019
Re: Welders
« Reply #7 on: December 19, 2019, 02:55:48 PM »
I bet he gets paid for it too  :lol
Alas' Stacey David uses Miller  8)
Offline dave2002ti
  • Member 2019
Re: Welders
« Reply #8 on: December 22, 2019, 08:21:06 AM »
Forgot about Stacey and we like Stacey better cause he used to have a rescue collie.
One day need to learn to weld. It will come in handy when I buy the farm so my collies ahve sheep to work.
  • Member 2019
Re: Welders
« Reply #9 on: December 31, 2019, 07:54:16 AM »
Now you've done it Garner. Planted another seed in my head.  I'll likely be picking something up in the next few weeks, so I'll have to read up more on ESAB.
  • Member 2019
Re: Welders
« Reply #10 on: December 31, 2019, 08:45:25 AM »
Rich you can't go wrong with any of the big names Miller, ESAB, Lincoln. The little inverter style, that can do everything is the best way to roll but also the price reflects it. If you want one to last a lifetime and never need an upgrade, you will never regret going that route.
  • Member 2019
Re: Welders
« Reply #11 on: December 31, 2019, 09:10:22 AM »
That's the plan. I want this to be a "one and done", from the welder perspective.  Now I have to also look at plasma cutters. An oxy acetylene torch is a bit rough for some of the stuff I'd like to do.
Online Gr8Dain
Re: Welders
« Reply #12 on: January 01, 2020, 07:28:22 PM »
A friend used a Plasma Cutter (Miller I think) to cut some thick metal brackets for my rear bumper.  Man, it was impressive haw it went through it like butter.  I would have been there for days going through cutting wheels (and possibly more slices to my face) if it were not for that tool.
2015 JKU - Completely stock - Family mobile
President: Stephen Clough (overhead) | Vice President: Donnie Herrity (Jeepin_Donnie) | Secretary: Robyn Kronthal (sticksout)
 Jason Markvart (LNDSRK)  | Steve Scott (Islander90) | Josh Storer (Jastor)| Mike Finelli (BiggMike) | John Harper (Opie)
