Author Topic: What did you do to your Jeep today? - December 2019  (Read 2465 times)
Offline Ta Tonka
Re: What did you do to your Jeep today? - December 2019
« Reply #15 on: December 05, 2019, 04:45:19 PM »
Added the PS hood louvre kit.
« Reply #16 on: December 06, 2019, 07:51:58 AM »
Thanks to Rich, my wallet is a lot lighter, but the Freebird is a lot cooler:
I also started the install of the MC springs and OME shocks. Rear first:
Hope to finish the fronts over the weekend in addition to the MC CAs all the way around.
33's
Rear D44 with ARB locker and 33 spline cromo shafts and 4.88 gears
Offline RFH_98TJ
« Reply #17 on: December 06, 2019, 07:52:18 AM »
Looks great Dan!  Is it crooked?  Haha!
98 TJ 4.0 Sport 5-speed - 4" lift on 35s, 4.56 on D30 with Lock Right and Ford 8.8 LS, Lots of welding
- Frank
Offline Ta Tonka
« Reply #18 on: December 06, 2019, 07:58:39 AM »
Of course it is! Now I'm gonna go knock it back straight at The Cove!
Offline RFH_98TJ
« Reply #19 on: December 06, 2019, 08:16:56 AM »
Wish I was going.  I did get my rear rebuilt at least.  Too much to do with mom coming in next week from MB.
- Frank
Offline Irish_Wake
  • Arlington, VA
« Reply #20 on: December 06, 2019, 09:38:06 AM »
That bumper looks great on there, Sarkis!
Also, we're looking pretty similar with the OMEs
2000 TJ Sport
~4" total lift
33x12.5R15
Truetrac D30/Locked D44
« Reply #21 on: December 06, 2019, 09:42:19 AM »
Very Cool Patrick, looks great!!  I see you are running stock control arms.  Let me know if you are interested in the JKS adjustables you see in my picture.  I'll be putting on the Metal Cloak arms sometime soon.  Let me know.
33's
Offline Irish_Wake
  • Arlington, VA
« Reply #22 on: December 06, 2019, 10:01:38 AM »
I've got some JKS already, thanks though.  I couldn't get the upper frame side bolts out, and just wanted to get the axle on for now.  Will be adjusting the pinion angle and hopefully installing driveshaft this weekend.  Good luck with the metalcloaks.  Are you putting them in all around?
2000 TJ Sport
~4" total lift
33x12.5R15
« Reply #23 on: December 06, 2019, 10:17:18 AM »
Awesome.  Yes, I'll be installing all 8.
33's
« Reply #24 on: December 06, 2019, 04:29:10 PM »
Just out of curiosity, what made you choose the OME shocks with the MC springs?
« Reply #25 on: December 06, 2019, 04:37:03 PM »
That’s what Rich sold me 🤣🤣. Also, with my rear lower mounts outboarded I need a little stiffer shock. I’m still going to run my Rancho 5000X shocks in the front. If those are to soft, then I’ll try the OME since I have them.
33's
Offline jdavis2nd
Re: Re: What did you do to your Jeep today? - December 2019
« Reply #26 on: December 06, 2019, 05:01:13 PM »
Are the OMEs that soft? I thought the reason MC recommended them is because their springs are stiff. For example they tell you to absolutely not use off the shelf Fox shocks because paired with their springs it's a rough ride.
I know that I ran both fox and OME springs on the JK. No complaints with the Fox but the OMEs where the perfect.
« Reply #27 on: December 06, 2019, 05:11:15 PM »
My understanding is the OMEs are in between the Rancho 5000X and the Bilstein 5100s.  I have the option on the front since I have some Rancho’s in the right length already. I’ll try them both and see. My rig is pretty light so I figure the softer the better. We shall see.
33's
Offline gravitywell
« Reply #28 on: December 07, 2019, 10:48:17 PM »
Ordered a small pallet of Metalcloak parts.
Sent from my SM-G965U using Tapatalk
2018 2 Door Wrangler JK - Willys W
« Reply #29 on: December 08, 2019, 08:00:53 AM »
I've run Ranchos, Bilsteins, and OME springs with Metalcloak 3.5" springs.  Out of the three, the OME shocks were the best ride. They are soft, but not to soft, and have great downward travel. The only negative side to them is that the shock body is huge. The Rancho 5000x is my next choice and I'd never run a Bilstein on a TJ. The Bilsteins do work on an LJ, but are way to stiff on a TJ running Metalcloak springs.
BTW, your wallet may be a little lighter, but you're going to end up with a rig that will flex awesome for a SA suspension!   ;)
President: Stephen Clough (overhead) | Vice President: Donnie Herrity (Jeepin_Donnie) | Secretary: Robyn Kronthal (sticksout)
 Jason Markvart (LNDSRK)  | Steve Scott (Islander90) | Josh Storer (Jastor)| Mike Finelli (BiggMike) | John Harper (Opie)
