I wanted a setup to air up my tires but didn't want to spend a ton, so I started a project. I want to get some ideas and thoughts from you guys. The compressor itself is pretty amazing and powerful, its a knockoff of all the others, but at $120 with coupon, I decided to get it. I cut out the factory board and based on a chat with a buddy and several online people decided to go this route. I will tap a pressure relief valve, located in the second pic, tap a 70-100 psi cutoff, 3rd pic, and also tapped the factory hose fitting with a quick release in 2nd pic. I also have a 200 amp relay to install as well as a 6 gauge jumper cable set that will connect to the system as the factory hoses and cable were a bit sketchy and got really hot when used. In the 4th pic I have the cables that I plan to use at first, then I will connect Anderson plugs and remove the cables, but for now, this will be the setup. I also made a flexzilla hose for 4 tires with a manifold. everything cost about $300ish so far. THe power from the motor is run using a smaller diameter wire, but to the battery I am using 6 ga, I plan to solder the connections for that, but need to figure out a way to keep the cables from being yanked around in that little area, not sure how to do that yet. I also have a 100amp Midi fuse for the cable.
Any thoughts or suggestions?
