Author Topic: AC leaking  (Read 76 times)
Offline Rotts2004LJ
AC leaking
« on: June 14, 2021, 06:50:30 PM »
It appears that the air conditioner is leaking on the passenger side.
Suggestions on where to start? Is this something simple to repair? Or should I take it to my mechanic?
Thanks in advance!!
John
  • WC
  • Committee: Website
Re: AC leaking
« Reply #1 on: June 14, 2021, 10:54:38 PM »
Do you mean it is leaking in the cab?
'03 Rubicon- 4.5" Clayton LA, 37"s, A bunch of skids by TNT, Poison Spyder, EMP, Rock Hard, Warn, Kilby and custom fab work.  CAI, Power chip, Exhaust, 4.88 gears and chromoly axles by Yukon. OBA and Powertank, one ton hi steering, Anti Rocks sway bars, MM 9500lb winch and a bunch of other stuff.
Offline Rotts2004LJ
Re: AC leaking
« Reply #2 on: June 15, 2021, 04:30:00 AM »
Yes inside the cab, flooding the floor. It was bad enough that the water made it to the rear passenger side floor as well.
I found a video suggesting clear the drain in the engine compartment so I did that last night. I'll run the AC again today and see what happens.
Re: AC leaking
« Reply #3 on: June 15, 2021, 06:49:04 AM »
Based on your screen name, I assume you have an LJ?
If so, it is common on the TJ/LJ models for the cowl vent to get clogged and hold water. Then that water gets into the intake for the HVAC system.
Just a thought.
Sent from my iPad using Tapatalk
