Author Topic: Savvy/Currie tj/lj control arms  (Read 248 times)
Offline scottk
« on: November 17, 2020, 06:44:59 PM »
2 sets of savvy control arms. Some off the jam nuts may need some heat to break loose.
Have most of the bolts.
Also have a hellwig rear sway bar and hardware.
And a Currie rear trackbar.
Cleaning out garage and they need to go.
Sent from my SM-A015V using Tapatalk
2005 LJ Rubicon, 35's
Offline SkylinesSuck
Re: Savvy/Currie tj/lj control arms
« Reply #1 on: November 17, 2020, 06:51:47 PM »
I'm looking for a set! Where are you located?
Offline scottk
« Reply #2 on: November 17, 2020, 07:01:40 PM »
Vienna
« Reply #3 on: November 17, 2020, 07:05:47 PM »
Can I come by next week?  Do you have a good time?
Offline scottk
« Reply #4 on: November 17, 2020, 07:13:14 PM »
Anytime is good. I can always leave them in the driveway if I'm not here
« Reply #5 on: November 18, 2020, 05:48:23 AM »
Awesome, sign me up for a set and the track bar please.  Curious about the rear sway bar. How is it different/better than stock?  I will PM you a couple days before hand to coordinate.  It'll probably be Monday, or maybe in the AM this weekend.
Also, if you want me to grab everything just to get it out of your hair I will then pass the other set along. I know how getting rid of good free stuff goes.
Offline scottk
« Reply #6 on: November 18, 2020, 07:44:15 AM »
probably best to grab both sets of controls arms. Good to have some extra parts in case you need to mix and match the best joints.
I also have the Currie Johnny joint rebuild tool that i'll  throw in.
The hellwig rear swaybar is just  beefier than stock -- its a 3/4 in bar- so a little stiffer
« Reply #7 on: November 18, 2020, 09:09:02 AM »
Great. Okay, I'll swipe it all from you.  Is Monday good for you?  What kind of beer do you like? ?
Offline scottk
« Reply #8 on: November 23, 2020, 05:40:54 PM »
Everything is gone
« Reply #9 on: November 23, 2020, 08:03:24 PM »
Thank you again! They will go to good use and I will pass along what I don't use  :jw
