Author Topic: What did you do to your Jeep today? - December 2019  (Read 3069 times)
Re: What did you do to your Jeep today? - December 2019
« Reply #30 on: December 08, 2019, 08:12:47 AM »
That’s what Rich sold me 🤣🤣. Also, with my rear lower mounts outboarded I need a little stiffer shock. I’m still going to run my Rancho 5000X shocks in the front. If those are to soft, then I’ll try the OME since I have them.
My understanding is the OMEs are in between the Rancho 5000X and the Bilstein 5100s.  I have the option on the front since I have some Rancho’s in the right length already. I’ll try them both and see. My rig is pretty light so I figure the softer the better. We shall see.
I've run Ranchos, Bilsteins, and OME springs with Metalcloak 3.5" springs.  Out of the three, the OME shocks were the best ride. They are soft, but not to soft, and have great downward travel. The only negative side to them is that the shock body is huge. The Rancho 5000x is my next choice and I'd never run a Bilstein on a TJ. The Bilsteins do work on an LJ, but are way to stiff on a TJ running Metalcloak springs.
BTW, your wallet may be a little lighter, but you're going to end up with a rig that will flex awesome for a SA suspension!   ;)
Yes, I can’t wait to get the new setup out on the trails. I’ve got the front springs on and the front lower arms. I need to get new hardware for the front uppers and install the rear arms. Hope to get it finished up today, but will probably bleed into the week.
Rear D44 with ARB locker and 33 spline chromo shafts and 4.88 gears
« Reply #31 on: December 09, 2019, 09:02:04 AM »
I installed a couple U joints on stock front and rear drive-shafts I picked up from Patrick.  While re-installing the front drive-shaft back in the Jeep, I got three of the four bolts in on the transfer case side.  While putting the fourth bolt in, I dropped the 8MM socket and it managed to fall in between the joints.  :twist  Now, I can't get the socket out without removing the three bolts.  Normally, this isn't a big deal, but I have the skid plate installed, which makes it difficult to get to the bolts.  Needless to say, I cussed at it :rf and walked away for the day!
« Last Edit: December 09, 2019, 09:03:42 AM by Runner »
« Reply #32 on: December 09, 2019, 09:29:26 AM »
Sounds like my kinda luck Rich. Though if it went in it should come back out without going through that again?
« Reply #33 on: December 09, 2019, 11:05:32 AM »
One of those cases where it went in, but won't come out.  I couldn't have done that if I tried....as you said, it's the way my luck runs.  On the positive side, I'm close to having the TJ back to driving status, after removing a majority of the drive-train and suspension mods.
Online Gr8Dain
« Reply #34 on: December 09, 2019, 12:08:52 PM »
I picked up a transmission (aw4) for the Scrambler last night. And continued to look ip parts for the swap.
Offline Irish_Wake
  • Arlington, VA
« Reply #35 on: December 10, 2019, 02:54:16 PM »
It sounds like by giving you my parts, I've managed to pass on my luck as well.  Maybe this means my curse is lifted?  ;)
2000 TJ Sport
~3.75" total lift
33x12.5R15
Truetrac D30/Locked D44
Offline JP-XPLR
  • Member 2020 VA4WD/BRC
« Reply #36 on: December 10, 2019, 08:41:12 PM »
In preparation for getting the Jeep out on the trail, I installed my first exterior mods as soon as the UPS guy showed, a Fishbone Offroad mid-width bumper and a Quadratec winch with synthetic rope.
Before:
During:
And after:
US Army Veteran - Berlin Brigade, 101st Airborne (Air Assault) Division, 2nd Infantry Divisions (Camp Bonifas & Stanley), Department of the Army (Walter Reed & DIA).
2019 JLUR, 2.5” MC Game Changer, BFG KM3 35’s on Fifteen52 Turbomacs, Fishbone bumper, Quadratec 12k w. Synthetic.
« Reply #37 on: December 10, 2019, 10:32:06 PM »
Finished up the install of my new to me MC adjustable control arms and 3.5” springs:
Also did an alignment, so she is ready to roll. Hopefully they don’t salt the roads.
« Reply #38 on: December 11, 2019, 06:04:54 AM »
I'm hoping you didn't pass it on to me!   :D
« Reply #39 on: December 11, 2019, 06:08:47 AM »
Did you check the brake lines?  From the angle of the last picture your brake lines look short.  Could just be the angle, but those springs have a tremendous amount of downward travel.
« Reply #40 on: December 11, 2019, 06:33:24 AM »
Good point, I had not checked that. I had to unbolt them from frame when I pulled the CAs to install the springs. I have a feeling they are fine since the shock was also an inch or so past full extension. I’ll check it out though, thanks Rich!
Sent from my iPad using Tapatalk
« Reply #41 on: December 11, 2019, 06:08:38 PM »
Did you end up with a little extra lift?
« Reply #42 on: December 11, 2019, 07:06:46 PM »
I ended up measuring the front at a little under 3.5” in the front and 4” in the rear. When I go to 35s, I’ll put the 5/8” spacers back on the front.
« Reply #43 on: December 13, 2019, 09:17:32 AM »
Changed the oil this morning, so cold out there, all business to quickly get the job done.
unl1mtd@novajeepers.com
Online Gr8Dain
« Reply #44 on: December 13, 2019, 09:19:40 AM »
Dang. You must have HAD to get the oil changed today. Bot sure I would have voluntarily done that today. Heck, I am looking at my CJ in the driveway knowing all of the work I need to do to it and just can’t get motivated. Way too cold.
President: Donnie Herrity (Jeepin_Donnie) | Vice President: Hiam Agha (BLACKHAWKJEEP)| Secretary: Robyn Alley (sticksout)
