Yes, anytime I shut it off for a few minutes up to around 30 minutes. It's the usual vapor lock symptoms, but on the original engine it only happened on the really hot days. Now it happens all the time.
2002 TJ
Hmmm. That's interesting.
I will have to think on what might be causing it but I do have an idea for a solution.
I saw a few years back, a guy on YouTube had the same problem. He had hood vents but it just wasnt enough. So he bought two electric fans, mounted them on the bottom side of the hood and used a thermostatic controller to operate them. If the underhood temp was too high when he shut it off, the fans would run to help pull out the hot air then they would shut off once the temp got below the preset temp.
I can look for the video if it is something you might be interested in.
