Member 2023
As if I do not have enough project going on right now. Taking a down day is always dangerous for me as I tend to catch up on some of my favorite car shows. This particular show was of the Great Smoky mountain Jeep invasion. The guy had a great build based on a late 60s M715. He turned it into a mobile Work shop for his business. this set me thinking.
Concept is based on the Kaiser M715 "Five Quarter" weapons carrier ( aka pickup) for the army. As built this rig came with an open cab/soft top and less than Steller accommodations for the driver and passenger. Axles are D60 front and D70 rear at 73.5 WMS to WMS length with a closed knuckle and drum brakes. transfer case is a NP 200 1.91:1 low range divorced and a Warner T98 4 speed. Factory motor is a 230 6 cylinder which is grossly underpowered but will move the rig down the road on an almost 6:1 gear set...
The plan is to Swap the cab for a J10/20 pickup cab. The sheet metal all works for the front clip and the body lines align for a weather tight cab. Pull the Tornado 230 Six and find a 24v Cummins 5.9 and a 6 speed manual trans for power.
Axles are 30 spline stock, so either find a custom length and move up to 40 spline or ditch the axles and go with a more modern set up from a dually with Disc brakes all around. and locker(s)
Interior plan is to set it up like a Grand Waggy comfy and plush.
Bed I have some overlanding ideas that might make it way into the plan.
Overall goal is to be able to drive this on the road as a daily driver / tow pig and still off road to a moderate level. With the right gearing and balance of power the set up should get something like 20mpg unloaded and 15mpg with the trailer.
The search begins.
The search begins.
